Randy Brunson
I swapped out the rod guides and all seals my trim cylinders over the weekend and everything was going well until it came time to refill the reservoir and bleed out the air. Basically, I couldn't get enough fluid in there for it to do anything. I think I screwed it up as I was looking at the Bleeding procedure instead of the installation procedure. I believe that process works if you've already got a good bit of fluid in the reservoir.
I circled around afterwards and was looking at other areas of the shop manual and found a few things in the assembly/installation procedure. Here are some things I messed up and could use some advice on.
1. The shop manual calls for 50-something ft.-lb. of torque on the rod guides. The instructions that came with the new rod guides called for 104 ft.-lb. Have I damaged anything by overtightening? Can I back these off and continue to use them?
2. In the shop manual, it specifies that you should maintain a lint free environment. Rookie mistake, I wiped out the cylinders with a shop rag when i was cleaning out the old fluid. Is there anything I can do at this point to try to get any lint out?
The rod guide set was about $45. Of course I don't want to buy another set, but will if necessary.
Any other tips on the procedure for filling the reservoir from empty would be helpful. Thanks!
