Have an ‘03 with 1700 hours, problems started as rough idle progressed to motor stumbling for several minutes before enough power to get boat on plane. When I started to troubleshoot I found water on dipstick and in cylinder #3. Took for a compression check and found the following:
#4-90
#3-125
#2-165
#1-190
Also water found in cylinder 4 during compression test
Obviously something is wrong, could be cracked block or potentially a bad head gasket. Is there any way to confirm what the issue is without removing the head ? I would prefer to not spend money to rip the motor apart to find the problem if I am missing something obvious.
Thanks,
John
#4-90
#3-125
#2-165
#1-190
Thanks,
John
