Hi all I have a couple of queries
can anybody point me in the right direction here.
I am in the process of rebuilding a used 50a. When I bought the unit from ebay it came with an old set of unusable choked carburators. I have since managed to get a set of good SE type units but I am unsure if I have to make any modifications to the wiring . I understand that the SE type units are powered all the time and the choke was switched to operate , do I just plug the SE lead into the same connector as the choke,or is there a modification I have to do.?
next up
I have my engine running on test in a water bath , but my idle seems to be a bit rough , I have reasonable compression on all units 195 ish hot at Wot, I have done a few syncros and have an
idle of around 1000 +_ 50 but it seems to stutter a bit , if I pull the plugs I have the following
pull no 1 stalls the motor
pull no 2 not much change in rpm
pull no 3 definite change in the rpm
from that it would seem that no 2 is not doing very much at idle ,I have had the carbs off and cleaned and all seems to be ok inside . It responds reasonably well to throttle but since I am running in a bath I cannot put it under load. Do you think that I still have a carb issue (no2) or is it possibily an electrical one ?
I have checked all the sparks and they all seem to be good at cranking speed , the mixture screws are all set at around 1 turn , now on investigating the carb issue I found out that the emulsion tubes are different for the SE units would that matter to the running of the engine or does it get the same gas as the older choked carb models
FYI I am able to run the engine by shorting the terminals on the 14 pin connector and the thermal choke has a seperate 12 volt feed
Thanks in advance
next up
Thanks in advance
