My 1999 Honda 90HP 4 stroke outboard is having the following problem:
When I turn the key to start the outboard, I will hear a click. But if I turn it off and on several times, eventually the starter will act as normal and start the outboard. I took it to a marine repair shop and they tested and said the starter was going bad so they replaced it with a generic starter. For several weeks the starter worked fine but then it started doing the same thing as the old starter.
The repair shop said voltage was going to the new replacement starter just fine so they replaced that starter with another new starter. Once again, all seemed fine for a few more weeks but the same problem returned- it started clicking just like the others. So, I went back to the repair shop where they double checked all voltage and connections. All checked out fine. I then asked if it would be possible that this outboard might require a genuine Honda starter instead of the generic ones. With that thought, they ordered a new starter from a Honda Marine dealer. That was 5 months ago and we are still waiting for the Honda starter.
But after thinking about this problem for some time, I wonder if it's not the starter at all but something else? I would appreciate any suggestions or ideas on how to proceed. Thanks!
