avidskier1973
Howdy fellow boaters, I'm new to this forum and hoping to get some help with my Honda 50HP Fourstroke.
I purchased a used Rendova 14 with a 1996 Honda 50 hp four stroke. Before purchasing the vessel we took it on a sea trial and then out again after the deal was done and the Honda seems to have behaved well.
Later that day I brought it home and tried running fresh water through the motor with ear muffs but no water come out of the tell-tale which worried me. I didn't happen to notice whether or not the engine was peeing when we had the boat on the water (I assume so.)
I'm not a certified mechanic but have a basic understanding of engines and started to dig around the old interweb for possible issues. Some of the information suggested I look at the thermostat and impeller/water pump. First I poked around the tell-tale connections to the engine and made sure nothing was obstructing flow. Purchased a new thermostat (the old one was cruddy and probably seized). I also ran some water through the thermostat housing (when I had the lower unit off) to make sure nothing was clogged and water did come out through the bottom. I checked and also replaced the impeller (the old one was not in bad shape) but for under $100, for both parts, I took care of two potential issues and gave myself some additional peace of mind.
I put everything back together and initially, there was a good stream coming through the tell-tale. Shortly after, I assume when the engine got up to temp and idling, there wasn't much water coming out of the tell-tale. I did submerge the lower unit up to the anti-ventilation plate inside a large bucket.
The question is, do I have a bigger issue? Should I remove the water jacket and check for additional obstructions or salt deposits that may be clogging the cooling system?
The boat spent most of its life in fresh water and was tender for a sailboat in NY and owned by the same family. It's been in the saltwater for the last couple of years. The owner assured me that it had been flushed after each use and he did have some maintenance records to prove the engine was taken care of. I did also read that the tell-tales are finicky on these motors but after performing the service, and checking for obstructions, I'm at a loss.
Any thoughts would be appreciated.
