travis0332
Hello, I have a 77 Merc 500 that I got runing by replacing some of the wiring, but it runs like crap. The engine had good compression, 112 on all 4 and has spark. After letting it idle (very roughly) I decided to pull plugs and take a look. Plug 1 had a little wet oil on plug. Plug 2 started smoking (white smoke). Plugs 3 and 4 looked steamed clean. It looked like water dribbled out of plugs 3 and 4 as well.
I'm pretry certain I have a major water leak. Is this a major overhaul not worth fixing in an engine this old?? Or could a DIY semi mechanically person have an attempt to repair this kind of issue. I have only done basic maintenance before - (carbs, water pump, stator, rewiring).
Thank you for you assistance!
