bonefish96
Hi All. Have been reading through all of the threads here and there is much information applicable to my situation but need advice on a few items I haven't seen covered specifically. I have a new to me 03 BF225 which came with a boat I purchased in the fall. About 800 hours. The motor has some issues that I was aware of when purchasing - the two major ones are:
1. Mid section is corroded/blown out as a result (I have learned here) of mid shaft bushing.
2. Engine starts great, idles great, and runs great up to about 4K rpm but then gets an overheat alarm and goes into limp mode. Can run it all day below 4k.
I don't have a ton of service history on the motor, the guy I purchased it from owned it for about 3 years and just did routine maintenance (I believe I know the marina where service was done from new/first owner to his ownership so I may be able to get some records from them). When previous owner started seeing the motor overheat he had his mechanic look at it and that is when the mid section issue was discovered. His mechanic just patched the hole in mid section but that apparently did not address the overheat issue. PO didn't want to troubleshoot it so I basically got the package for the price of the hull.
After buying the boat I just topped off the tank, added stabilizer, ran the engine on muffs, pulled the plugs (looked good) and sprayed WD-40, changed lower unit oil (looked good), checked oil (looked almost new) but haven't changed yet. At this point I'm looking for a little help for a game plan on getting the motor up and running. I'm planning on oil change and filter, possibly new plugs (even though they look good with good gap?), new impeller, new thermostats (i did pull these last weekend and tested - both functioning properly but a decent amount of gunk built up and o-ring on port side was toast and clearly had been leaking), new racor, new anodes. Based on what I've read here I should also be doing lp and hp fuel filters. All of the aforementioned I think I can reasonably handle myself - I'm mechanically inclined but haven't owned an outboard for about 10 years and never a 4 stroke.
I have located a used mid section for a reasonable price (from an '04 I assume compatible with my '03?) - is this replacement reasonable to try to tackle myself? Anything else I should be doing in terms of deferred maintenance and to try to address the overheat issue? Read a post from chawk_man describing IAB baffles that are supposed to open around 3950 rpm that can get stuck - is that something that could cause overheating as that's the rpm range where the engine has problems?
Any help appreciated on how I should attack this!
