Was out on the boat about 45 minutes into it. It started to bog down and wouldn’t get above idle. Drained the water separator, and sounded like we were starting to lose cylinders. Got back to the house, and started to check into it more. None of the cylinders have any spark, the fuel pump is running and took a spark plug out to see if there was any spark. All cylinders don’t have any spark, didn’t see any flashing codes. Swapped out the main relay. We still don’t have any spark on any of the plugs. Checked the kill switch and neutral switch those are good and working like they should, if anyone has any ideas on what the cause of the problem we’d really appreciate thanks in advance!
