I have an old BF2 BAES model that has a blocked main jet in the carb. Does anyone know hot to remove the carb or at least the fuel bowl?
I pulled and cleaned the tank and made sure that the fuel filter that is in the tank end of the fuel line was not plugged because that has caused me problems in the past. I also pulled the bowl nut / drain needle valve. The ports in the needle valve drain were plugged which I cleaned. I can now open the fuel valve and get fuel to come out the drain so fuel is making it to the carburetor.
Now I can get it to start and run but only on full choke. If I open the choke at all, it dies no mater what rpm I am running at.
That sounds to me like the primary jet is plugged. Easy right? Not so much. On this old Honda, the bowl and all of the carb is blocked by the lower housing and I cannot see how to remove it. It looks like the engine might need to be completely removed from the housing to gain access.
Here is a photo of the serial number plate. the number is BAES 1222809
Here is a photo of the carb covered by the housing.
looking from the side. It looks like if the light gray cover below the fuel cutoff was removed, you could get to the carb mounting bolts. The problem is that I cannot see anything that is attaching it to the engine.
Here is a view looking up at the bottom. I have removed the black guard but the hole above is too small to remove the bowl with the light gray cover above.
