The first bit of info that should be provided, and the first question that should be asked is;
What Type Of Cooling system?
Raw Water cooled engines, or... Closed System Cooled engines?
It is difficult to get the correct help, until this is known.
This is none of my business chiming in on your thread here, but if open to hearing this, read on.
Please DO NOT think that allowing the sea water pump to pull Anti-Freeze up and into the system, and then seeing this come from the exhaust, is going to offer you protection!
It does NOT! Not in the way that many think that it does if you were planning to leave this in!
Those who do this are not considering "dilution" from existing sea water in the cooling jackets! (I.E., a complete "exchange" of sea water for "anti-freeze"!)
Nor are these guys considering the amount of "heated" Anti-Freeze that is required to cause the thermostat to open..... nor are they understanding that MOST all sea water (Raw Water Cooled engine) is By-Passing the actual engine demands.
Only that coolant (sea water) required for "Cooling" is allowed to leave the engine on an "As-Needed" or "On-Demand" basis as the thermostat dictates!
Meanwhile, most of this coolant (anti-freeze, in this case) is by-passing, giving these guys a
"False Positive" when they see anti-freeze come from the exhaust system!
I see this all to often!
All looks good this time of year! We don't see the actual damage until Spring Time..... when we find cracked engine blocks and/or manifolds.... or both.
Always see your Engine Specific OEM manual, and follow it to the letter.
Remove all low point drain plugs, and leave her dry!
Air will not freeze, expand, and cause damage!
You can't go wrong if you do this.
Best tip that I could offer anyone:
Learn the entire path of the sea water..... from the pick up point, to the exit point!
Find it in schematic form..... and varify it physically.
Follow this path, and you will find all low point drains.
(block, manifolds, oil cooler(s), circ pump suction hose, belt driven or crank pumps, suction hoses, and so on.)
Probe your engine block and exhaust manifold drains with a wire or equivalent.
This dislodges any rust scale that may prevent the water from draining completely.
Drain these.... and if you want the
"Feel Good" feeling, pour your anti-freeze in (temp sender port and/or thermostat port),
but always drain this again afterwards.
As for closed systems......., the H/E will also have a drain in it that should be removed. This is usually your pencil anode as well.
Again, follow the sea water path on these closed systems also.
Some view fogging carbureted engines as optional. However, the added protection is never a bad thing.
Fogging can be done in as little as 8 to 10 seconds @ 1,200/1,300 rpm.
While the instructions make no mention of this....., if we
Kill our ignition while we continue to fog, we prevent combustion from burning up the fogging solution during the last few revolutions as the components come to rest.
Dual plane intake manifold engines must be fogged equally into each plane. If we do not do this...., we leave 4 cylinders unequally protected.
For those who can remove their impellers for the layup duration, fogging can be done during this very last "dry-start", and with ZERO harm being done to any exhaust component.
Again, it takes about 8 to 10 seconds to do this!
This ensures that we limit residual water in our exhaust (possibly destine for a open valve/cylinder).
I've been doing this for as many years as I can remember. Never once had an issue!
Your call on that!
