RicardoMarine
Gold Medal Contributor
1... as a general rule, you'll want to consult only those with real Marine experience.1.... Was told that the engine is the same as a car, and nothing will happen. But i guess the person knew as much as i.
2.... Then i found out that the engine cools with fresh water.
3.... I thought that i wont be able to winterise and be more screwed than i am now. Will try to do work this weekend temp will be +25 till Monday with full Sun no clouds.
The engine is indeed an automotive engine that has been modified for Marine use. The differences are subtle, but none-the-less, are different in many respects!
2.... over the years the cooling types have taken on a "misnomer" meaning....., so to speak.
Fresh Water Cooled is often confused with both River/Lake water cooling (aka "open" or "raw water" cooled) and is sometimes used to describe the "Closed Cooling" system (aka heat exchanger and ethylene glycol as do our car/truck engines)!
Basically (and to avoid confusion), we want to used the terms: Closed Cooling system and/or Open or Raw Water system.
Apples/Oranges!
3.... do what you can to drain any residual water from the engine and exhaust system. These will be all low points where water may collect and remain.
While I don't believe in over-hauling a previously "raw water" cooled engine (especially a salt water engine), it may be worth saving the engine components.
Keep in mind that you're only a few dollars away from good automotive cores that have been E/G cooled their entire life.
Woodie, fogging may not be absolutely necessary...., so I agree with you on that premise!Wow, thought I was the only person on the planet that believed fogging a 4 stroke for short layups wasn't necessary.
But what if this boat were to not make it to the water the following season????
It is so easy to fog one, and fogging does offer additional cylinder wall protection......, If/When Done Correctly!
Yep! All Winterizing looks perfect in the Fall...... it's Spring Time when we learn just how well it had been done $$$$$$$$$$$$!......... The usual Spring threads on cracked blocks I suspect are due to lack of knowledge or lazy practices and oversights.
I'd suggest if you want to over-haul one..... or over-haul this current engine.........., that you start a new thread on the topic.
There are some simple Do's and Don'ts that will be critical.
