My thoughts:
Chris and Woodie, I agree..... if there is any residual water at any low points, it does pose a risk.
It also poses a risk if we add E/G and when it does not mix thoroughly with the residual water. We then close things up thinking that all is protected!
This is why some suggest doing so, but draining this again afterwards.
Now we have only air that will not cause expansion damage, and we have some E/G protection, both with the residual water, and with regard to iron oxidation protection.
Any rust scale caused by just plain air, will be so minimal, that it won't register on any scale (no pun intended).
I'll take the rust scale over the risk of residual water freeze expansion!
But then again, I don't own any open cooling system boats.
The other thing that is risky, is pulling E/G in through the out drive (or thru hull pick up), and then thinking that when we see E/G come from the exhaust, that we're done!
NOT SO!
We must consider the raw water that the T stat is holding back, and that most raw water is going right on and through the exhaust.... giving us a False Positive!
Please DO NOT do this!
At least not without draining everything again afterwards.
I cringe when I see these videos advertising these systems, and that when you see E/G come from the exhaust, you're all done!
As for adding stabilizer to the fuel tank, do this during your last run, and let the boat do the shaking/mixing for you....... or, if you trailer, take the boat for a short ride down a rather lumpy road.
You can also remove the fuel filter, dump it into a container, and then add an oil rich mixture to it, re-install, and run the engine until this mixture reaches the carburetor, TBI or EFI.
For those with carburetors, fuel evaporation is what may cause issues.
Part way into the lay-up period, an oil rich fuel mixture can be added to the fuel bowl vents.
This will slow evaporation!
Pick yourself up one of these;
These work great for spring time start-up also... but with anything like this, use extreme caution!
I use one very similar, and it is always placed outside of the boat during starting.
Anyway, just my further two cents on the topic!
