New owner. 1996 Sea Ray 7.4 Mercruiser I ran the engine till hot then used the Camco winterizing jug filled with RV anti freeze till the exhaust had pink coming out. I then drained the block and both manifolds. They had hot RV anti freeze come out. Is there any reason I need to fill the block and such again with anti freeze? Located in Northern Mich so it will be below freezing. I am also unable to find a power steering cooler and I do have power steering so does that also use raw water where it would be winterized with the method I used? Thanks for any info.
