makesumwake
Why did this rebuilt engine fail?* Was it the engine rebuilder’s fault?
I recently purchased a rebuilt 350 GM marine engine from a cheap engine rebuilder.
Block #10243880, aluminum pistons, bored .030 over.
CONFIGURATION:
Mercruiser inboard-outboard setup, 2 barrel carb, salt water cooled.
This engine failed after 10 hours of normal use.* Oil was shooting out the dipstick full force (massive blow-by) and lots of white smoke from burning oil.
After failure compression check results (triple checked):
1 - 90 psi
2 - 180 psi
3 - 150 psi
4 - 0 psi
5 - 180 psi
6 - 0 psi
7 - 30psi
8 - 180 psi
(Unfortunately, no compression check was done for comparison before using engine)
Tear-down by engine rebuilder revealed chip out of top of #7 piston, chip was melted to top of piston.* The piston also has a crack running down the side, right under the point where it chipped.
See all pictures here, the rest of the pistons looked ok.* All rings looked ok.* Cylinder walls were ok.* There was a raised ridge on #7 cylinder bore where the piston had failed.
pics
http://s144.photobucket.com/home/makesumwake/index
No issues found with #4 and #6 pistons / rings / bores.* Zero compression on 4 and 6 must have been due to sticking valves.* Discoloration/rust on #4 and #6 valve tops confirm this?
Engine never overheated - Overheat alarm never sounded, checked temperature of engine with temp gun while running, verified correct operation of water pump, water flow was verified, thermostat was checked and found to operational.
Engine had sufficient oil before failure - oil levels were correct, new oil pump had been installed, oil pressure gauge never showed lack of oil
Engine wasn’t running lean.* Spark plugs, piston tops, valve tops all blackened with carbon.* Carburator was taken to carb shop and verified to be a good working order.
Engine cam/crank shaft alignment was verified to be correct before engine assembly.
Spark timing was done by setting distributor to fire #1 plug when #1 cylinder was at TDC, on compression stroke.
Engine had brand new exhaust manifolds (salt water cooled) and brand new risers.* All new gaskets were installed.
Upon installation, engine started right up and ran great / sounded great.* No hesitation or lack of power.* Smoke start coming out of breather a few hours later.* Finally a lot of smoke and oil was noticed spurting out of dipstick when engine was run WOT.* Engine was idled home immediately after this.
Engine builder claims it isn't his fault.* He claims that the valves were sticking due to being melted.* The #7 piston damage occurred due to ring becoming red hot, expanding, and forcing piston to chip.
This explanation is BS right?
He claims that melted valves and piston was due to incorrect timing.
I think that he performed a poor head job, resulting in sticking valves.* And he installed a bad piston, resulting in the damage.
What do you think?
CONFIGURATION:
1 - 90 psi
2 - 180 psi
3 - 150 psi
4 - 0 psi
5 - 180 psi
6 - 0 psi
7 - 30psi
8 - 180 psi
pics
What do you think?
