Changing the oil and filter for the first time on my new HOnda 4 stroke 8 hp. The manual says to get to the filter remove 6 bolts and remove the R. engine cover. When I look at that to get the cover off there are 2 black plastic fittings sticking through, I wedged them out and they are permanently connected to something inside with little hoses.
I assume when they R they mean right when looking at the motor from behind it? Because this is the side where the oil drain screw is. Anyway, I couldnt imagine what the 2 black fittings were so removed the other side engine cover and there is no filter there.
Can anyone help? Maybe on the first side you pull loose the 2 black plastic things and just hang onto the cover while you are replacing the filter? No way I am disconnecting them and the manual said bolts. (btw these are screws, not bolts) My problem is I am up on a ladder working on a sailboat on a trailer. Almost impossible to hold the loose cover in one hand while messing with the filter Very long day with no success.
