Ok just sold my 1999 lund pro-v /2000 115 honda on it today or so i thought. The motor has 45 hours on it used very little hence the reson i sold it. Anyway the guy that bought it was very nice and seemed very knowlegable about lunds and bout motors in general. So to my suprise i get a call from him saying he took the boat to the lake let it idle for 10 min checked to see it was cooling and everything working properly. Then took off down the lake cruising at 20 to 25mph and the said the motor just locked up on him with no warning lights or alarms. He said he's had alot of experience around boats but had never seen anything like it. He talked to a mech at his marina and they told him it sounded like the lower unitand asked if i had put gear lube in it. Well i hadn't used the boat this year yet and it stayed in my garage all winter. Wheni stored it last fall i popped the lower gear lube screw/plug to check for water, there was none i let out maybe 4 - 8 drops of gear lube, put the plug back in and called it good for the winter. Now there was no oil leakage on my garage floor this winter either. Yes i should have checked it before i sold it but so should have he. I do know the oil in the engine was good (synthetic and very clean )so i didn't bother to change it last fall but did check it this spring and it was full. The only other variable would be i had hit 2 logs back in 2007 when i first bought it on atrip up in canada, replaced the aluminum props back then and also had an issue with the little metal tab on the neutral safety switch (bent it back in place to work) during tha same trip but has worked fine ever since. LIke i said ididn't get to use the boat alot but last year hit another small branch out in the middle of the lakethis prop was a 17 pitch but could just barely see any bend to it. Because there was so very little vibration when driving the boat just used it at the end of summer. SOOOOOO!!! My question would be what are the first things to check when i get the boat back tomorrow. I know the guy told me it won't run or start just nothing, he also said he put a wrench on the motor (where i don't know) and tried to turn the motor over and said he couldn't turn it at all. He said he's still very much interested in buying it. And yes ive been told that i hold all the cards given i've put the check in the bank and he has the signed title, and i could just walk away sold as is. But i'm not that type of person so any suggestions would be very much appreciated. Thanks
