jimturner44
I have a 150 HP Johnson 1996 J150EXEDB. I get no spark on any of the 6 plugs. I replaced the stator with a new one. I did all the resistance tests in the shop manual on the Coils, plug cables, checked the rectifier diodes, cleaned all grounds, checked the neutral cut-out switch - all things that could cause no spark. then I check the A/C voltage coming out of the stator coils. All three stator coils read about 25% of their expected voltage. Example, I read 23 volts on from the charging coil and the manual say it should be 100 volts. What to you thinks it is. Could it be weak magnets in the fly wheel? The magnets are all in tact and firmly in place. Need some troubleshooting advice to pinpoint the issue.
