I have a 1993 Evinrude 120. Water comes out of the pee hole, but not with great pressure. When I changed the water pump last year, I noticed the previous owner had used pliers of some sort and messed up the rounded edge at the bottom of the water tube. I suspect there is not a perfect seal, so some water is pumped up the water tube, but not all of it and not at the correct pressure. I purchased a new tube and gasket on eBay, but I have not attempted to change it yet. What is involved with replacing the water tube? This is my second year owning this boat, so I am still learning a lot. I am going to check the thermostats and their housing for crud before I change the tube, but I want to see what I am getting in to. Also, is the copper water tube standard 1/2" or 3/4"? Could I in theory cut off the bad section and solder on the new section with a female to female copper fitting?
Ideas would be appreciated.
Thanks!
Thanks!
