Recently, I found water in crank case. I took it to a mechanic I've used in the past, and the
results were....if he ran the engine in the tank....everything was fine...But....if he ran the engine with, "muffs".....
he got water in the oil. Any idea of.....what gives?? It's a 2006 BF50A
Thank you in advance,
TM2
*He put the engine under 50 lbs of pressure over the week-end, and it never lost an ounce...all gaskets were
tight and fine.
TM2
tight and fine.
