This is the ciff notes version of what I found on my sons Merc 4.3. Not sure of the age of the boat, but guess it at 15 years
He bought the boat used last year. He used it most of the summer. It seemed doggy to me and ran a bit rough. The bilge would have water in it after a day on the lake.
This spring he ask me to get it started for him. I pulled it home, charged the battery, put on a set of ear muff cooling cups. The engine turned slowly but did start. I noticed water dripping from the bottom of the engine into the bilge. Shut it off and recommended he take it to a local boat repair shop, he did.
They replaced the starter, drained the oil (quite sludgy from the way it was explained to me) and changed the spark plugs (still the original plugs, painted in) . Found the leak,a freeze plug. Ran the engine and found water in the oil. They diagnotised the problem as exhaust manifold leaks. Replaced the manifolds and tested the engine for 3 hours at the shop. My son picked up the boat ($3,200.00 later). Put it in the lake and it ran very well...for 30 minutes then seized up.
We talked to the boat repair shop and they were at a loss to explain the reason it failed. They indicated aprox $6,000.00 it they have to replace engine. That is not going to happen, my son can't afford that. We decided to take this on ourselves (should have done the exhaust manifolds ourselves but didn't have the time to get in done for a graduation party he was planning)
Build a 12' high by 10' wide ganty crane out of 2 x 8's and a 1500 lb winch I had laying around. Pulled the engine yesterday. Have it on an engine stand in my garage. Went to drain the oil today. The first few drops were WATER. And the oil is cloudy. Obviously there is still a water leak somewhere in the system yet. So now we have a (in all likelyhood) a spun bearing and a water leak.
The reason I an writing this is to ask how do I check the cooling system for leaks? I am fairly handy around the garage (just finished a 2 year restor on a 69 Camaro) but I'm not familar with the cooling system on a marine engine.
Any suggestions would be greatly apprecaited.
Tom
Tom
