kghost
Silver Medal Contributor
Yep, manifolds, risers and elbows will be replaced. Inspected butterflies, all looked good. Will be adding all new worm gear clamps as well.
Parts should be here Friday or Saturday.
Regarding the oil change after about 10 hrs or so... already have the oil and filter for it.
Lastly, does anyone have any insight why the water exiting the exhaust had one side cooler (by about 20 degrees) than the other side?
I'm just curious if this is an indication of any other issue, or maybe nothing.
Thank you all
That is normal, there are hundreds of posts here asking the same thing.
Water flow takes the path of least resistance......
Also the hotter side manifold/elbow may have issues. Thus the suggestion to replace all on both engines
