2000 BF130 (530 hrs)I've been struggling with my #1 cly fouling the plug. Yesterday I de-carbed with sea foam. The motor misses at idle. Struggles on three cyl trying to get up on plane then the #1 kicks runs fine but burning about 20% more fuel until I come off the throttle. then the process starts again. Today took the valve cover off to check valve adj. To my horror, I found the dreded cafe latte oil. Drained cleaned and put the flush kit on. Water is entering the crank case. I should say a lot of water.
Is there anything I should check before pulling the heads? I've babied this motor since new. All premium fluids and maintained to specs.
