Water from powerhead
It is an inline six cylinder and yes it is leaking through the spark plug area. Is the correct part "term" a water jacket gasket. I am having problems getting the right part.
I need advice on this motor. It is a 1974 115 horse two stroke inline six cylinder motor that has been leaking water out of the spark plug holes when in operation. The serial number is 3762229. I believe what will solve the water leakage is a water jacket gasket. I have ordered what I thought were the correct gaskets but have found them to be incorrect.
Motor gasket wrong part.MOV (file://DESKTOP-3SJB94U/Users/Administrator/Desktop/Motor%20gasket%20wrong%20part.MOV)
Here is a link to the picture of the wrong gasket and a pic of the motor head. I got them from Marine Engine
I have ordered this.
I have the correct water jacket gasket. Now I am looking for the gasket that goes between the power head(bottom) and the lower unit. Trying to attach a picture of what I am talking about but the file is too large.
Resize your photos to under 1Mb
It can be done right from this site. See the little button at the bottom of where you type, the one that says ATTACH FILES?
When you click on it, you get the option to chose a file from “photo library”, or take a photo.
Once you chose one from the library that is already on your phone, (it will open your entire library), select the one you want. Now, before you do anything else, look at the bottom left corner- it will say OPTIONS.
Choose that & you get choices of LARGE, MED, SMALL. Try one, it will give the new size that will be attached. If it’s less than 1Mb, say 294Kb, then select DONE, then ADd, up at the top right.
Thanks. I have tried what you are suggesting but I am not getting to the area to obtain the choices of size. I am working from a laptop and my I phone.
Thanks for the tips on how to resize photos. This is the picture of where the gasket goes on my 1973 two stroke 115 horse inline six cylinder Mercury outboard motor. The serial number is 3762229
