Hi all
Got the engine running right and ran into another possible problem. At slow speed (from idle to about 2000 rpm the boat will not track straight. It will wander to starboard and slowly back to port and slowly back starboard, etc. If you try to correct each heading change it just makes it worse and keeps the helmsman real busy! If the wheel is left alone the boat will get to the desired heading with an "S" wake. Any suggestions?
I'm not sure this is the right forum, but none of the others seemed to fit.
Another quick question that does fit this forum. I came across a manifold for my AQ131A. Mine is a single carb, single throat Solex. The one I came across was a two carb manifold. As this boat is being built to troll on lakes the fuel economy is important (troll all day and not worry about refueling). If the dual carb could be set up as a progressive linkage I could troll at low throttle settings using just the one carb and then when it's time to get back to the dock, open it up and run with both carbs. Anybody heard of this or have any thoughts?
Thanks,
Martin
Thanks,
Martin
