knowlescamper
"I have a 1999 Four Winns Hori
"I have a 1999 Four Winns Horizon with a Volvo Penta 5.0GL engine. It starts, it runs, it quits. Fuel pump is good, fuel relay is good. Upon starting, power is getting to the relay in order to close it. When in normal run, the relay is not getting power to close, therefore the fuel pump won't run.
I've heard there are two sources of power to the relay. One is from the starter switch--it's fine. Another from the alternator. On one board, an oil pressure switch was mentioned. I have been unable to locate it--is there one, and if so, WHERE is it?"
