Screamin283
Hello everyone,
Sorry my first post has to be a request-for-help, but I'm kind of at a loss here as I don't know too much about outboards. Some background info before I start, the engine in question is a Suzuki DT75. I bought the boat as a project (which I won't ever do again!) and I had the carbs rebuilt last month since the engine had been sitting for a year prior to me getting it.
The engine's compression is 120 on each cylinder. I have new fuel lines, a new primer bulb and a new water separator installed.
When I prime it, the primer bulb does get hard. But when you crank it, it cranks and cranks, and finally sputters, but won't run. When I crank it I am making sure the choke is activated; the choke does work and closes the butterflies when the key is pushed in. (Which, by the way, is a pretty annoying way of choking the engine if you ask me)
Now I know it isn't necessarily a good idea, but I sprayed some 2-stroke starting fluid I got at a marina directly into the carbs. Choked it and cranked it, and it fired right up and ran great - provided I kept the choke closed. It ran for probably a minute or two, so it was obviously using its own gasoline supply, but as soon as I let up on the choke it died.
So, I have basically two questions:
1) What would cause the engine to be so cold blooded? Like I said the carbs were cleaned out, fuel lines replaced, and fresh gas used to run it. Spark plugs are new. Perhaps a weak fuel pump?
2) If I am going to have to keep the engine choked for a long time to warm it up, is there any reason I couldn't wire the choke up to a switch on the dash - I am not sure I have the patience to sit there pushing that key in for 10 minutes.
Any insight or info is appreciated. If you need more info, don't hesitate to ask! Thanks!
