Bought a boat with a motor that has no lower unit. 300 verado pro. Knew this going in. The motor has no oil in it as dropping the lower unit drains the engine oil (according to the sticker on the driveshaft housing). I have my concerns about the motor being any good as well and would like to do either a leak down or compression test on the motor before I spend money on a lower unit.
1-since engine oil drains out the lower unit, can either test be done without the lower unit on? Should be no issue I believe.
2- if it can be done, will bump turning the engine for a compression test without oil be ok? Should I spray a fogging oil in the cylinder first? Would raising the motor to a full horizontal position keep any oil in the crankcase or would it still drain out in that position?
3-if neither test will work do I have any other options?
Thanks in advance
Thanks in advance
