Hello OMC folks - I just brought home an old boat with a 2.5 litre (I think) 4 cyl GM engine and stringer drive - about 1972 I think - looked like it hadn't run in a couple of years at least. Are these old Chev Nova engines??
The upper thermostat housing was freeze cracked across the top and some water was still in the exh manifold when I drained that but I was suprised to find that the engine would rotate at the crank pulley and there is no water in the oil. When the crank pulley rotated to a certain point it jammed but when I rotated it backwards it went past that point the first time around and then stopped at the same point the second time thru - so now I'm thinking stuck valve and that this is an interference engine and feeling really smart and that this thing might run again after all.
But when I took the valve cover off it looked like all the valves were moving back to closed or at least close - certainly none were open very far if at all when the crank pulley would hit - so quickly lost the smart feeling fast! I'm a pretty good mechanic but not on marine engines - What am I missing guys?????
Ron
Ron
