I have a 21 foot Nautic Star 2007 with a v8 Mercruiser. Bought it last July and put a lot of hours on it from July to November. Stored it for the winter and when it got warm again, took it back out of dry storage and it wouldn't crank. Looked at a few things and the first issue that we found was a diode for the fuel pump was bad. Replaced that and it cranked right up. Well next time I took it out, it wouldn't crank. This time, we found that moisture was building under the distributor cap, so we replaced that. Cranked fine. Next time I tried to run the boat, wouldn't crank. Figured we probably fouled out the plugs from all the times we tried to get it to crank the last two times it didn't run. Replaced plugs, cranked fine.
Took it out this last time and I had it in neutral in the marina and it was idling kind of weird. Went out of the marina and opened the throttle and boat ran fine. Once I hit a no wake zone and slowed to idle, the boat stalled on me. The only way I could get it to crank back up was giving it throttle while cranking. It refuses to stay running unless it's basically wide open.
The boat ran so fine when I bought it with literally no issues. Now every time I fix something, it's just something else immediately wrong. What would cause it to stall during idle? What's weird is when I had it running for 10 mins in the marina, it didn't cut off at all in neutral. My first guess is the IAC valve or maybe my fuel pump is bad? Anyone experienced this and any recommendations?
