Other Line
Guys,
Been chasing an overheat issue. I can idle all day long with no issues, but once I hit 4k overheat alarms go off and she goes into safe mode. Got her on the water yesterday, did it twice in a row, then it went for 20 minutes at 4200 RPM, but when I bumped it up to 4800 she alarmed and shut down.
Took the heat gun with me this am. idled for 30 minutes and both cylinder banks read 107ish on the gun.
Pushed her up to 4000 and alarmed within 20 seconds. Facing the motor, left bank read 137, right bank read 184.5!
Idled home with no problems. First thought is a bad t-stat on that side, but I replaced them both less than 50 hours ago. Also, this T-stat " cavity" developed a pencil sized hole from corrosion at 600 hours ( right after I replaced the Mid-Section!). I used MarineTex and it lasted 30 hours, secound fix was with SteelStik and it's been good for about 200 hours.
I am going to put the t-stat on the stove to see when it opens.What temp should it open at? I forgot. If's it works right, I have the following concerns: I got some debris in the cooling passages during the repair, or I have built up the patch Area to much and it's interfering with the t-stat opening.
Thoughts?
Thoughts?
