Unidentified part on my lower unit
There is no reason for that to be there and certainly was not that way from factory.
Looks like a previous owner may have been using it as a ground wire for who knows what? (cav plate mounted electric trolling motor?????? - some theory to prevent galvanic corrosion???????)
Uhhh.... thats the factory installed ground straps part # 88238A2. It purpose is to ground swivel bracket to driveshaft housing. All inline and V-6 motors with 3 ram trim have them. The inlines have two straps and the V-6 have four...
What is the thing on the lower unit that has a cover that is right by that ground wire??? That seems to be there on all engines like mine
your engine probably only has one...replace it...without it you are relying on getting a good ground thru the swivel bearings or sleeves...thats no good...
