matt.speedtriple
Hi Folks,
I`m looking for some advice from a wiring guru in regards to my later 1970`s TX Hydraulic Trim Tabs Wiring.
I bought this boat a couple of months back and have been having a real battle with the engine and cooling system but i`m finally starting to see the end of the tunnel with that so started looking around the rest of the boat to see what else isn't working as Mr.DIY had owned it before and really screwed most things up.
During my digging about then i came across the trim tabs pump and motor that was still attached to the pipes but i couldn't find any switches anywhere on the boat to operate them??? After tracing the cable then it turned out that Mr.DIY didn't know what they were for so just cut the cable and discarded the switches. (Yes i will be completely rewiring the boat over the winter!)
Anyway, I've removed the whole pump assembly from the boat just now to check it works but need some advice how to do this before paying out for replacement switches only to find it`s dead. I found a wiring diagram in the boats paperwork which i've scanned as have attached below plus marked what i`m missing so any advice on which wires i should +power together to test it would be a great help.
Cheers, Matt.
[/IMG]
Cheers, Matt.
