Jackthebear
Vessel: 1998 Formula 330 SS with twin 7.4 MPI's with Bravo III's and about 360 hours on each. Boat has 1 battery selector switch with Off, 1, both, and 2 selector options.
Issue: Boat starts and idles great. When I give it throttle in gear, both engines accelerate but quickly lose RPM while simulataneously the voltage meter jumps from 13.8 up past 16 volts.
Troubleshoot: I ran the boat in 1, 2, and both options of the selector switch chosen and the issue remained the same. I ran the boat with no accessory switches on and the issue remained the same. I checked for a loose ground connection at the batteries (2) and at the battery bus bar. I checked the back of the selector switch for a loose connection. I check the 12V panel board for a loose connection. Everything appear to be tight and not corroded.
Question: Has anyone else had a similar issue and/or does anyone have any suggestions or ideas as to what could be causing this issue and the best way to remedy the situation.
Thanks in advance for the help.
Jack
Jack
