hairdresser100
Hi All,
I have twin 1997 BF90A outboards on my boat and I read somthing in the Honda factory service manual that I need to learn more about.
It reads, if you install twins you CAN NOT run them both off one battery so I installed two batteries with two 1,2,all switches.
It also says if you do need to run both engines off ONE battery you must disconnect the negative wire that grounds the two Honda control panels together that's located on your dash.
What is this all about????
If I did run the engines using only one battery what did I screw up???? I notice one volt meter jumps to 14 volts and stays there like a rock but the other one is sluggish and drifts around a little depending on RPM...but is always above 12 volts and stays at 14 when on plane.
My email is [email protected] (not spam or ....)
