Here is the situation: One Engine which engages the VTEC Overheats. The other engine fails to engage the VTEC mode but does run upto 5K RPM without overheating.
So could the engine that is not energizing the VTEC be causing strain on the engine that does energize VTEC then overheats?
I been chancing the Overheating issue and not the other engine that doesn't go into VTEC mode.
Looking at the engine w/o VTEC working i do have oil pressure and solenoid confirmed to operate when I swapped it on the other engine. I guess I might be stuck wiht pulling valve cover for more inspection.
Really at a loss here, any guidance is greatly appreciated.
