"I have an aluminum motor exte
"I have an aluminum motor extender that is hollow. Water collects in the hollow section, making the boat too heavy in the stern. I've determined that the water is most likely getting in through where the large disk anode mates to the surface. On this extender, there are two disk anodes, one on the inside and one on the outside that are connected by a single through bolt. I've cleaned all surfaces and tried to tighten them down as much as possible, but they still leak. Is there any type of sealant I could use that would not defeat the connectivity necessary for the anodes to work properly, but would seal them so water would not get into the extender? If not, does anyone have a way I can work around this problem?"
