RPAYNE
I am building a new bottom end due to a cracked block on my 96 mercruiser 350 mag. I am having a difficult time finding a piston with an adequate design for a proper quench build.
The engine is carbureted and has pre vortec 14096217 heads, which are the same casting as the 083 iron l98 heads.
64cc D shaped chambers, 194/150 valves
Mercruiser specs this engine as 9.4:1 compression although with a .039 gasket and stock full dish pistons I come up with 9.0:1? Anyone know what the compressed thickness of the mercruiser/sierra marine head gasket is?
I am having an extremely difficult time finding D shaped inverted dome pistons that would mirror these chambers.
The only ones I have been able to find are Keith Black KB193-030
specs:
12cc dish
1.561 compression height
By my calcs this would give me 9.64:1 with the block cut .025 to give a proper quench right at .038 with the felpro marine hg at .039 compressed - even a few points higher if heads need surfaced.
IS THAT TOO HIGH? I will be re-using the mercruiser roller cam (low hours) and was hoping to come in around 9.4:1 - I don't wan't to have to be picky about gas or worry about detonation and will be more than happy to have the same power it had. Any hp picked up from the superior piston design would be a plus. I could live with sticking to premium fuel (only have 91 reliable here) if I had to but would love to be able to run 89 or even 87.
Other options with these jugs
1. Bump quench to .045 at 9.49:1 compression - not a huge difference in comp for giving up quench
2. Open the chambers up a bit and try to add 1-2cc or to the heads could get sub 9.4:1
3. KB also has an 18cc piston but even dropping quench to .035 + surfacing heads only yields slightly over 9:1
I have also seen mixed opinions of KB pistons. Lots of negative or so-so sentiment out there while others say they are fine and have a bad wrap stemming from their wider ring gap requirements that have not always been followed.
My building uses Speed Pro H423DCP for all his stock + builds and swears by them. They have a wider squish band around them than the stock full dish but to me they seem marginally better.
Their specs are
12.3cc dish
1.548 compression height
So numbers would be very similar, required a few more thousands off the block to make quench clearances and compression would only be .03 lower. Speed Pro seem to have a decent reputation though and are cheaper than the KBs.
Is anyone aware of any other options because it seems like there is nothing else currently available which baffles me. This is a common cylinder head chamber shape. Or do you have experience with KB pistons and input on 9.64:1 - 9.7:1 compression and what fuel that would require?
Thanks!
specs:
12cc dish
Their specs are
12.3cc dish
Thanks!
