"What is involved in replacing
"What is involved in replacing the tilt,trim motor on a 1992 120hp Johnson?Does the port side engine mount have to be removed?If so what is the removal procedure?I watched someone try to remove an engine mount that appeared to be frozen to the tilt tube with a 2lb hammer and he totally mangled the tube.I would like to do the repair the right way and would like to know what problems if any I might run into.Thanks"
