Trigger voltage on Mercury Black Max 1979?
Peter Devil Ears
Hi, anyone know what the voltage on the brown wire is on a 1979 Black Max, 175HP V6? This is the wire going to the tachometer. I want to build my own digital tachometer, so this is why I need to know this value. Thanks for any assistance. Peter.
The tach is driven by keyed AC (pulses) from the charge coils on the stator. Depending on the configuration of the bobbins and the magnets you get anywhere from 4 to 20 pulses per revolution.
While there is specs out there for the ignition side of things, I have never seen any for the charge side (at least coming directly from the stator charge/lighting coils), before conversion to DC.
The charge bobbins produce AC that is rectified to DC either with a rudimentary rectifier (which outputs between 13.5-16.0 volts DC on average depending on rpms - never dissected one but suspect it combines the peak AC both positive/negative after filtering with high/low pass circuitry into a single positive keyed DC stream ) or is rectified/regulated to 13.5 volts by a voltage regulator.
The "signal" for the tach is parsed off before the voltage is rectified, so can only assume that it's AC pulses with a peak power somewhere between 13.5 and 16'ish volts.
The 175 Merc produces 12 pulses per rotation, and again, never stuck it into a scope so can't say if would look like a pulsed stream, or due to distortion, a keyed square wave.
(now making me think here - dangerous :))
It should be simple to produce a digital tach. Would only need a "counter" that divided the received pulses by 12/per minute..
Your other option, which is produced commercially by a product called "Tiny Tach" (plus a number of clones) is to take a feed off of one of the spark plug leads.
This simple "digital" tach is nothing more than a "timing light" that is connected to a counter. Since each cylinder only fires once per revolution, the basic counter simply counts per minute...
