got a new timing tool its a dial indicator that goes in # 1 hole first I got the piston on top dead checked timing mark on flywheel it was dead on 0 ok next I counter clock piston to 3.81 MM down = (25 degrees timing ) checked my timing the mercury mark on flywheel was at 28 degrees not 25 deg did this two more times same thing setting on 28 deg ..... so should I run it at 28 deg indicator timing.... are mercury marked 25 deg...........2.5 mercury 150 Velocity Stacks exhaust tuner short one Boyesen power reeds
