Good Evening! Have a leak coming from the port (t/t motor) side of the assembly and have questions about removal. Removed clips, and bolts, etc and the assembly won’t tilt out since it catches on the edge of the t/t motor (where the wiring pops out of the case). Is this normal? Or perhaps this t/t motor is an aftermarket?
So I go back to my manual and see I should be able to slide the bolt from the lower cylinder bushing section to remove the entire unit... bolt removed and... the unit isn’t coming out. The wave washers have something to do with it?
I now see (in the diagram) there’s a lower cylinder collar - perhaps that’s made its way into a stern bracket and is holding the unit up? Rubber mallet didn’t help but it did pop the t/t motor off the pump assembly. Unit is covers with a garbage bag until the new t/t motor comes in.
Tomorrow ill I’ll go back out and see if the collar moved into a stern bracket in addition to any other suggestions...
