Scorpio4life2019
I recently hooked up Tilt / Trim to my 1978 Merc 70. I can get it to go down great. But it won't go up.? Any suggestions? Thanx Roger
Thanks for responding. So the fluid is brand new when I got the pump it was empty so I filled it. I'm wondering if I didn't bleed it right or something. The cylinoid is brand new as wellHow does the fluid look? Is it clean or clouded with moisture?
thanks but I have already done thatSwitch wires on the solenoids,if the motor goes up,replace the solenoid.
Is the pump motor turning for up ?----Is there a knob on the pump reservoir / valve body that needs to be turned ?
Just about the time that you think you know something some engineer comes up with another way to skin a cat, thanks for the info.
