troym
Advanced Contributor
1997 5.7L, 2bbl mercarb, TB V (w/o knock sensor), Alpha I Gen II.
Seems I've been chasing my tail alot with following symptoms, all of which have been intermittent, in no particular order, no appart cause during recurrance and follow-on disapearance of the symptom(s): lack of power, rough idle, poor fuel economy, and stalling shortly after restarts when engine is warm.
What I've done so far:
- checked all ignition wiring for shorts, grounds, bad terminal connections, etc. ...no smoking guns.
- new dist cap and rotor. Old ones weren't what I'd consider bad, but cheap and easy enough to replace.
- new plugs and wires. Old ones same as above.
- replaced carb needle and seat, replaced power valve, verified correct float level and drop, cleaned carb. Checked float weight (9 grams). Once again, no smoking guns.
- replaced fuel/water separator and fuel filter on carb. No smoking guns.
- fresh fuel, added stabilizer. No reason to suspect bad gas, used the boat enough this summer to keep the gas pretty fresh, unless I got some bad gas from the gas dock.
- checked & cleaned fuel tank vent cap screen. No smoking gun.
- checked fuel pressure.. 7psi. (mechanical pump) No smoking gun.
- checked choke setting and operation... 2 marks to open, opens about a minute after energized. No smoking gun.
- Set idle speed and mixture per the manual. (ICM in base timing mode, etc). No noticeable improvement, but at least eliminted this a possible cause for one of the symptoms.
After the last round of troubleshooting and eliminating possible problems (Sunday), I took the boat out for a test run. Had no reccurance of the stalling after restarting this time, but the engine had a noticable miss at idle, and it lacked power terribly. It seemed to accelerate OK up to about 3000rpm, but the miss got more noticable, and it really struggled to get the boat on plane.
Could this be the beggining of the end for my ICM?
I would think if it were bad, it would just stop working all together (i.e., no spark)
The troubleshooting chart for the ICM in the Merc manual doesn't help much... I have spark, the engine runs, it just doesn't run right.
