I just renewed top end parts ..................... My questions are mainly electrical
If this involved cylinder head work
ONLY, then you have no issues with piston rings. So running on the temporary base poses no issues that I can see.
It would poses an issue if you were attempting to seat new piston rings and intended to run for a long duration! For this, we need to properly load the engine.
a) What year/which ignition system? If this uses an EST system, use caution as to how/what you power up!
Your OEM engine harness will no doubt be installed on the engine......... so look at the hull harness schematic, and your ignition system......, and power up that which is necessary.
b) Depends on how the alternator is regulated. If externally regulated, I believe that you can spin it as long as the field is not excited. However, if your engine harness is installed and connected, this should take care of itself! Again, as long as you power up via the OEM harness.
NOTE: you make no mention of year model. If by chance your helm has an Amp Meter (not volt meter), then the engine/hull harness will take the charge circuit forward and back again. This must be "looped" in order to complete the charge circuit while you are test running....... but again, you make no mention of this!
c) No excessive pressure, only volume!
Is this Raw Water cooled, or does it have a Closed System?
A raw water system thermostat should have a small air bleed hole in it. This purges air from a dry cooling system upon start-up. (we do not want sudden cold water entering a hot cylinder block/heads)
Best to shut down water supply just prior to shutting the engine down.
d) I doubt you will find any Pros suggesting a "how to", as there are some inherant risks in doing this.... and too many systems to cover in one video! However, I just Google'd
"test running marine engine", and yes, there are some videos. I cannot suggest that these guys are offering a good
DIY'r Joe demonstration!
One video shows powering the ignition coil directly....., but makes no mention of the ignition system.
A less than responsible suggestion, IMO.
He also attaches full garden hose water pressure/volume to the sea water intake hose! The risk in this, will be over-supplying water that may become introduced into an open exhaust valve while the engine is
not running!
Use Caution and common sense..... you'll do just fine!
Again, Best to shut down water supply just prior to shutting the engine down.
