Patrickguilbert
I am having issues with a parasitc draw. It has traced back to #2 on the terminal block. drawing 1.7 when nothing turned on. iThe number 2 wire goes to the main connecter plug which then goes to the battery. If you disconnect the main wire going to the battery the 1.7 goes away and has zero draw. The number 2 wire is not connected to the rectifier so not sure if that is the problem. The engine starts fine. Any help on this would be appreciated.
