DBS-96fourwinns
Hello. I have a 96 fourwinns 200 and while out for the seasons first trip yesterday, the temperature gauge did something unusual. To start out, I just had the seasonal services done by my local marina and they replaced the water pump. They have a tank and ran it after repair and said all was good. Yesterday at the lake I was cruising out for about 15 minutes, all gauges seemed fine. Then I slowed to an idle and within a few seconds the gauge went up to around 220 degrees. Then started dropping about 10 degrees/second until it got down to 130, then the gauge just dropped to below the lowest reading of 120. Almost seemed as if gauge went out. But when I shut it off gauge drops lower , so it's still responding to ignition power. I checked to see if I had water flow coming out at the back and it seemed so , and engine didn't show any signs of actually being over heated . So I kept a close eye on it and was out for several more hours. Gauge never worked again. Boat ran fine. Is there a wire that could have got bumped near the water pump or was it just coincidence that the gauge went out. It's a ford 302 V8, OVC. I appreciate any ideas. Thanks
