My tacho stopped working last time I used boat. Took it back to dealer to investigate. The battery was charging normally but tacho did not work. They said electrics at outboard was OK. They connected another tach which did not work so they suspected possible issue with wiring loom? They re-connected old tacho and magically it worked again without changing any parts. Started outboard at home on muffs last weekend and tacho not working again. I noticed that the volt meeting on my sounder read 14.3amps when outboard was running and back to 12.4amps when outboard off so I assume changing is normal. Is there something else I need to look at or check?
