Hi there,
Some short while ago I posted a thread,that due to constantly only using synthetic 2-stroke oil I have reduced the mix ratio on my ´86 50Hp 4cyl Mercury to 75:1.
It was running perfectly and actually better than ever all through this and the last season.. until this morning..
I was speeding along and had not noticed that the impeller failed upon me!
All I noticed was a loss of power, -the feeling like fouled fuel, water in the carb, similar.. I reduced power, extreme rough running..it took me all of 10 seconds roughly to realize there is no way anywhere anymore.
Looking back all steam through the cowling. The motor stopped itself the same moment I pulled the quick stop.
A very shameful and embarrassing tow back into port, -and on first inspection after the motor cooled down on the trailer.., it appears no damage happened to the block! Compression on all four.
If that is confirmed on proper inspection, -I can truly say the synthetic oil has payed for itself, -and you can safely use it in smoke free mix ratio!
