matt.speedtriple
Hi folks,
Just a quick question in regards to syncing carbs. I finally got my boat in the water today after a 2yr full refurb right back to the fibreglass skin which was all that was good.
Anyway, when i fired up the engine then i needed to adjust the tickover as the water was cooler but i started getting the engine struggling and coughing. When it coughed then all of a sudden then the revs would pickup to 3000rpm but then fall back to around 800rpm.
I tried adjusting the mixture screws, put in new plugs and fitted new ht caps but still the same. I also replaced the fuel pump as i had one handy. The carbs have been fully stripped, put through my ultrasonic cleaner 3 times and then blown through with compressed air and then carb cleaner and everything way ok. After fitting the carbs (all gaskets replaced) then i balanced them but i`m now wondering if i should`ve removed the link bar between all 3 carbs before syncing them?
Further up the rev range then it seems to be fine running at 5500rpm wot and reaching 18 knots with 3 large people aboard.
If anyone has any ideas and also if the link bar (number 16 on the link below) should be in place when syncing the carbs then i`d be very grateful.
http://www.lingshondaparts.com/pe/h...ock_01=17ZV50E1&block_02=E 14&block_03=32051
Cheers, Matt.
Cheers, Matt.
