Supposed to do this
century19
"I've got a 1974 century a
"I've got a 1974 century arabian with a 440 RWC and paragon v-drive (connected to the cooling system) So I just replaced an engine oil cooler that was leaking oil into the water, and when I test ran the engine I noticed that water was only exiting the port side exhaust, untill the thermostat opened then very hot water would start coming out the starboard side and continue untill the engine cooled back down to like 110F 120F then no water out the starboard side. i let it run like that for like 20 mins at about 1000rpm and it cycled about 3 times i've got the 140F thermostat in it is it supposed to do that??
I'm thinking the faulty oil cooler was causing the engine to run warmer than it should causing the thermostat to always be half open so water would always come out both ports.
the only other thing that bothers me is after shutting the engine down i could hear water boiling and steaming in the star. side bypass hose."
Sounds like you've got a p
Sounds like you've got a plugged riser. Pull it off and 'drill' out the holes with an 1/8 inch rod.
Jeff
risers are flowing good. that
risers are flowing good. that was my first thought as well but when i took them off they weren't what i was expecting to see... they are cooled by water that is feed in the side from fittings rather than having the sloted holes. the side that isn't putting water out the exhaust is also feeding the water cooled v-drive. i wonder if that adds enough resistence to cause the prob.
"i'm also wondering if the
"i'm also wondering if the risers should aim up or is one of them at an angle on purpose
440
"They are ususally aimed verti
"They are ususally aimed vertically, but space requirements might dictate otherwise.
Jeff"
turns out the starboard side m
turns out the starboard side manifold had a crack in it...when i tried to start the motor after a long run on the lake it was hydrolocked....pulled the spark plugs from that side and found water rushing out. so i've got a new manifold ordered and should have this thing up and running again in a couple weeks...
